July 07, 2009, 03:49:33 AM *
Author Topic: ford 9"  (Read 50 times)
« on: July 03, 2009, 07:06:55 AM »
Typical 9" Case
Standard C7AW-E case
Standard D2SW-C pinion support
While its not 100% sure, the outer piece of the axles appear to be 31 spline, could be 28 still - unlikely I guess.
And here are some numbers I pulled off the case:
It appears that the "IL" I stated earlier is probably a "71" which probably makes it from the year 1971 ??
Here are more sets of numbers I saw:
98 or 86 stamped kinda on the side of the case
3K16 (has . . under the 3)
O2SW-C or D2SW-C
and DIF in raised letters near the "71" on the flat part that bolts to the axle.
and there is also a Sideways W which looks like it is eating to Cc's that are inside each other.
$150.00
located in Sterling, MA - no delivery.
« Last Edit: July 03, 2009, 07:11:29 AM by Mitch » Logged
My sites:
www.jeepmj.com
« Reply #1 on: July 03, 2009, 08:42:58 AM »
width? wms to wms
« Reply #2 on: July 03, 2009, 09:20:40 AM »
ill have to get back to you
Also, this will need breaks (drums) and some studs for mounting rims.
« Last Edit: July 03, 2009, 09:22:13 AM by Mitch » Logged
My sites:
www.jeepmj.com
Powered by MySQL Powered by PHP Powered by SMF 1.1.9 | SMF © 2006-2009, Simple Machines LLC | TinyPortal v0.9.8 © Bloc
