January 06, 2016, 03:25:44 PM
Author Topic: 3 link rear suspension  (Read 206 times)
Offline Casey L
« on: December 11, 2015, 11:00:00 AM »
Hi guys, I have been thinking of converting my Clayton style 4 link to a 3 link with a track-bar. Mainly to give more room for a larger and quieter exhaust.
It seems not too many people make a 3 link rear, has anyone seen it done or have any suggestions?
Re: 3 link rear suspension
« Reply #1 on: December 11, 2015, 01:42:25 PM »
the only place ive seen it done is on JK's due to where the gas tank is located....I know the Rock Krawler long arms are that way.  other than that I have no info for ya
Offline Casey L
« Reply #2 on: December 11, 2015, 05:13:29 PM »
I found a build that has a 3 link rear. Curious if the 3rd link has to be centered on the pumpkin, or if it can be mounted to one side without any negative effects during acceleration or braking.
http://www.rocksolidtoys.com/forum/showthread.php?t=628&page=22
« Reply #3 on: December 11, 2015, 06:42:03 PM »
I believe if everything is strong enough it shouldn't matter where the 3rd link is.  It doesn't matter on the front.  Just use a strong frame mount, brace the axle end and use big joints and big bolts.  I would weld the tubes to the pumpkin and make a nice truss to tie everything together.
« Reply #4 on: December 16, 2015, 10:57:14 PM »
What exhaust are you running with the clayton setup? I had two options and went the louder route (wish I hadn't) regular magnaflow sized universal cat and 10 series flowmaster.
 If you do a new full length exhaust with a small cat (universal spun magnaflow) with o2 bung welded in after and then a hushpower muffler from flowmaster, this should be relatively quiet driving with decent tone
« Last Edit: December 16, 2015, 11:07:51 PM by Krome »
« Reply #5 on: December 16, 2015, 11:10:16 PM »
Instead of the flowmaster muffler, do this
http://www.summitracing.com/parts/mpe-10416/overview/
Offline Casey L
« Reply #6 on: December 18, 2015, 07:47:13 AM »
I have a spintech 11" muffler with a cat from a Saab I think. That combination allows the muffler and cat to start and end under the skid plate / crossmember.
http://www.spintechmufflers.com/mufflers/street-mufflers/pro-street-6000/pro-street-6222-2a-a-center-2a-a-offset/prod_236.html
I will try and get some pictures this weekend.
« Reply #7 on: December 18, 2015, 10:19:06 AM »
Check your muffler bearings, they get loud after 2000km.
I think I saw you last week in traffic on RT3 south near Burlington.... That is all.
« Reply #8 on: December 18, 2015, 06:36:09 PM »
Does your exhaust exit out the back or just dump after the skid??   If it's just dumping, I would try to route it out the back, it'll help more then you think.
« Reply #9 on: December 18, 2015, 09:31:20 PM »
What he said, if its dumping underneath theres your issue. Also that muffler is a beast, get something quieter as well.
« Last Edit: December 18, 2015, 09:32:01 PM by Krome »
Offline Casey L
« Reply #10 on: December 25, 2015, 07:10:51 PM »
Yeah john that was me. I have been driving the jeep everyday the last few months.
The exhaust dumps out in the right spot. I think I will call spin-tech to see what they have that will quieter next week.
« Reply #11 on: December 26, 2015, 10:46:35 PM »
Can you move the cat up and get a different brand muffler? Maybe not as much of a "race" muffler?
« Reply #12 on: December 26, 2015, 10:46:54 PM »
Could also look to add a resonator to the setup
