May 31, 2015, 10:34:27 PM
Author Topic: Complete wiring diagram for 98 tj ?  (Read 1293 times)
Offline norx
« on: December 19, 2010, 09:50:41 PM »
Any ideas where I can get a complete wiring diagram for a 98 tj ? Father in law replaced 4cyl with a bored and stroked 4.3 chevy and we are completely residing whole jeep or should I say I am rewiring it any help much appreciated thanks in advance John
1997 Jeep TJ 4.0 5spd 4"zone off-road lift 35" pro-comp x'terrains
Re: Complete wiring diagram for 98 tj ?
« Reply #1 on: December 19, 2010, 10:15:09 PM »
Brooksy may have something
Online HEYzipupyourfly
« Reply #2 on: December 21, 2010, 04:16:39 AM »
I dont think i can copy paste, I need the year/model and trim and I can get the pinout. I can see what I can do about posting them here. I think there are safeguards against me doing such.either way i can see what I can do. which systems do you want?
Offline norx
« Reply #3 on: December 21, 2010, 09:38:22 AM »
Tony I need all the ones plugged in under dash on drivers side I'm removing the old harness completely so I need ign wipers horn lights gas gauge fuel pump etc. (all the stuff) :/ and does anyone know what will happen with the airbags ? it's a 98 tj also 4cyl five speed (well it was) thanks for all your help in advance Tony if emailing it to me is easier here's my email  [email protected] thanks John
« Reply #4 on: December 22, 2010, 01:36:34 AM »
ok I'll see what I can do.
Personally I wouldn't remove all of the harness though, I would leave everything non engine related minus ign and start circuits that are already in the jeep. then I would strip the 4.3 harness down to strictly engine only and power it with the ign hot from the exhisting harness. that would be the logical way to do it without breaking into stuff you dont need to.
That all sounds easy on paper and the way i said it but trust me it will prob take you more time to pin out both harness' and ecms, than it took you to do the whole swap and some.
Not to mention I would think you would want a new Map for the 4.3 since its been stroked, by the way where did you have the 4.3 stroked, I've never seen a stroker shaft for those things did you have it welded and ground? kind of a waste, if you were going for more torque, you would have been beter off with the 4.0L or just putting a stock 350, in my experience your better off going with stock applications, especially in something your going to wheel. because [censored] always breaks and its tough to find a stroker rod out of a junk yard when you drop one on the way home because you didn't realize you blew a hole in your pan. not to mention the $$ you'de have tied into that crank:)
« Last Edit: December 22, 2010, 06:29:05 AM by HEYzipupyourfly »
« Reply #5 on: December 22, 2010, 07:37:16 AM »
matching harnesses sucks time-wise. my suggestion is to lay the two harnesses out on either the floor or two folding tables (I don't like to bend over) lots of masking tape and markers to ID wires. I like to seperate what is under hood and what is under dash. then after I label everything, the I pin it out and combine into one harness deleting what is not needed.
Are you having the ECM re-flashed?
Dad always said "If it has boobs or spark plugs it will be fun AND cause you problems."
Offline norx
« Reply #6 on: December 22, 2010, 07:45:14 PM »
There's no computer at all it's got a edlebrock carb and high-rise on it . And I have a brand new 21 circuit wiring harness already mounted and ready to go I'll spice into the wires at the main harness plugs under drivers dash I just need to know what wires go to what :/ thanks again for any help John
« Reply #7 on: December 22, 2010, 09:52:59 PM »
I have all the 99 tj wiring diagrams, shoot me your email address and I will send them along.
Offline X-BoB-J
  • J33P
« Reply #8 on: December 23, 2010, 01:53:32 PM »
Just curious. Are you getting it inspected?
Offline brooksy
  • A wise man never plays leapfrog with a unicorn
« Reply #9 on: December 23, 2010, 04:51:25 PM »
I havent been on here in a long time so I appologize. I also have the diagrams for a 99 TJ if Posi can't hook you up.
2012 JKU
99 TJ
68 M715
Offline norx
« Reply #10 on: December 23, 2010, 05:48:48 PM »
Y bob j he's in Maine and reg as a custom and posi and brooksy here's my email jnorxjr@ comcast.net thanks and happy holidays John
« Reply #11 on: December 24, 2010, 08:01:53 AM »
sent
Offline norx
« Reply #12 on: December 24, 2010, 06:21:33 PM »
Thanks posi and brooksy I got both emails :) enjoy the holidays thanks again John
Offline X-BoB-J
  • J33P
« Reply #13 on: December 26, 2010, 11:09:21 AM »
ohhh i c, MA suxxxx
Offline norx
« Reply #14 on: March 01, 2011, 09:25:31 PM »
Ok it's done 4 weekends 1100 miles no idea how many hours I have successfully put new harness with old harness and everything works :) thanks Tony and posi the wiring diagrams I got from you both made it possible all 286 pages thanks again John
