January 26, 2010, 05:15:53 AM *
Visit Tread Lightly's website for more info!
Author Topic: roll cage info  (Read 125 times)
Fraser
« on: January 16, 2010, 08:02:09 PM »
Tubing and flat steel for extra support under a UNIBODY
and for reinforcing rocker panels..
Also diameter and wall thickness for roll cage stock...
I have heard 1 3/4 inch diameter and .75 thickness on DOM is respectable.. ( was thinkin thicker ? )
just lookin into things for future reference Huh?
Junior Jeeper
« Reply #1 on: January 16, 2010, 09:36:28 PM »
.75 thick Huh
that's 3/4 of an inch!!!!
that's a little overkill Wink
how about .20 for thickness or were you referring to the steel plating for the unibody?
cause 3/16 '' to 1/4'' works there
Fraser
« Reply #2 on: January 16, 2010, 11:41:58 PM »
ha ha rookie here .. still gathering info..
 but thanks
captain bolt on
« Reply #3 on: January 17, 2010, 05:42:21 PM »
For what you will be doing, you don't really need any extra bracing.  But if you can weld, and fabricate, it certainly won't hurt anything.  I'd go for .188" (3/16") for plating the unibody.  If you are new to fabricating, then skip the cage building project for now.  Its not totally necessary.  I doubt you will get yourself into a situation where you will REALLY need it.
And if you do build a cage, 1.75x.120 DOM is what most people use.
88 MJ, 6.5", custom 3 link front suspension, HP D60 5.38s welded, 14bff 5.38s welded, 37" Coopers on H2s, full hydraulic steering
"Never write if you can speak; never speak if you can nod; never nod if you can wink."
Moderator
When you get to heaven may the devil be your judge
« Reply #4 on: January 18, 2010, 08:51:15 AM »
I would do this first and formost. do it while teh body is still fairly straight and clean.
this is what My cage is made of.
A diamond might last forever, But she will never forget the crabs you gave her!
FLEX CAPACITOR
« Reply #5 on: January 20, 2010, 01:25:47 PM »
if your dom is going to be made of 4130 you could get away with something like .080 wall. but assuming your going to be using a mild steel like 4340 i would stick with a little thicker wall than that, .100-.120 is a popular size, and 1.5" tube is plenty strong enough no need to deal with 1.75" in my own opinion
good luck is the fallout of hard work.
Bad luck is the fallout of laziness and poor preparation.
