December 05, 2012, 01:19:17 PM *
Pages: 1 2 [3] 4 5   Go Down
Author Topic: Tow rig  (Read 3636 times)
Casey L
« Reply #30 on: May 05, 2008, 09:01:58 PM »
lol. Thanks for putting it into perspective todd. Someone told me that it was about 50/50 now with diesel so high, but I was kind of skeptical.
Ill race you in my coffee can import and show you whats up. Wink
03 Rubicon - Stock w/ 32's
« Reply #31 on: May 05, 2008, 09:23:34 PM »
i have money on the dodge
Casey L
« Reply #32 on: May 05, 2008, 09:25:06 PM »
 Grin
« Reply #33 on: May 05, 2008, 10:01:21 PM »
considering your import crap doesn't run i would def kick yo bum
good idea on betting on me kromie.  i have done a couple new things that would insure my win Grin
Switch
Do work.
« Reply #34 on: May 06, 2008, 09:19:35 AM »
I'll run you once I finish mine  Wink.
On a side note, what has to be done to a diesel to run biodiesel?
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
« Reply #35 on: May 06, 2008, 09:38:17 AM »
Todd, correct me if I'm wrong, but Nothing.
2000cherokee
OH Snap
« Reply #36 on: May 06, 2008, 12:49:32 PM »
a few of my buddies run bio diesel and i dont think they have done anything..
and i would put the money on the dodge over the import. chipped diesels are nuts
Casey L
« Reply #37 on: May 06, 2008, 01:05:50 PM »
You need a heater to heat up the biodiesel so that it becomes thinner. So you start your car up on regular diesel and then switch it over to biodiesel once it warms up.
« Reply #38 on: May 06, 2008, 01:07:26 PM »
Move to florida.   No mods needed and problem solved.
« Reply #39 on: May 06, 2008, 02:58:17 PM »
I might be mistaken, but isnt biodiesel not straight vegtable oil?  I know that there is some chemistry involved with biodiesel.  You need to heat the vegtable oil so it thins out and doesnt clog the fuel lines.
Even with regular diesel, the tractors at work have a very hard time starting at 30*.  However, this is without glow plugs.
« Reply #40 on: May 06, 2008, 06:13:40 PM »
bio is not waste oil, well it is but it is a different process.  you can run bio straight into your tank, nothing else needed.  if you want to run waste oil you need to pre-heat the oil and run it through a strainer then you can plumb it into your trucks fuel system.  it is a pita to run waste oil.  bio is already strained and it is mixed with lye and methane to bring it back up to snuff (so to speak)
« Reply #41 on: May 06, 2008, 08:54:56 PM »
Thank you Todd.
Switch
Do work.
« Reply #42 on: May 07, 2008, 09:46:20 AM »
thanks for the explanation
/l ,[____],
[---L--OlllllllO-
()_) ()_)—o—)_)
« Reply #43 on: May 07, 2008, 11:06:55 AM »
where do you buy bio?
« Reply #44 on: May 07, 2008, 04:23:43 PM »
some home oil delivery companies are selling it now.  i get it from a local guy
Pages: 1 2 [3] 4 5   Go Up
