September 10, 2015, 02:49:19 PM
Author Topic: What does breaking a locker sound like?  (Read 103 times)
Offline Casey L
« on: August 26, 2015, 08:46:35 PM »
Does it sound like this video at 0:05 seconds in?
https://goo.gl/photos/vS7x7Fv1Nuu7jn4r6
Re: What does breaking a locker sound like?
« Reply #1 on: August 26, 2015, 09:22:46 PM »
Maybe?  I don't think it was loud enough to be a locker breaking.
« Reply #2 on: August 27, 2015, 07:03:38 AM »
I assume you mean the rear since at one point your passenger rear tire wasn't turning.  from my experience when you break a shaft or locker, its much more intense of a pop.  but I know the rubi rear locker has gears inside for the limited slip that like to snap, so it might be a much more softer pop when those let go.
have you pulled your cover yet??
« Reply #3 on: August 27, 2015, 07:07:21 AM »
Cant be shaft because later in the video i'm pretty sure you spin the tire again..   My guess is locker or nothing.
Is it acting up while driving now?
Offline Casey L
« Reply #4 on: August 27, 2015, 11:32:53 AM »
Yes so this happened back in early June. And yes, I mean rear locker.
I pulled my diff shortly after a 1000+ mile trip, and there was nothing that looked too bad inside. I have a link over at Rubicon Owners Forum hoping that someone has experienced this failure mode before. http://www.rubiconownersforum.com/forums/20-tj-drivetrain-horsepower/91858-03-rubicon-locker-problems.html
I have wheeled 2 times since then, and used this as my daily driver for the past 2 months. No bad noises, but I am going to pull the covers off again this weekend.
Now neither of my lockers work. Both pumps work and hold pressure, but something is wrong. I am going to pull the covers and jack the jeep up this weekend to verify that the diaphragm is moving.
« Reply #5 on: August 27, 2015, 12:40:20 PM »
not sure how the older rubi lockers work but I know the locking pin on the jk's like to break so you cant lock them anymore
« Reply #6 on: August 27, 2015, 08:49:03 PM »
Moral of the story is to stay out of the ditch?    ;)
