September 10, 2015, 08:48:04 AM
Author Topic: Thriller MJ  (Read 54228 times)
Re: Thriller MJ
« Reply #690 on: August 03, 2015, 09:50:21 PM »
I have a minor clearance issue.  I'm going to fix this problem tomorrow.  Luckily I have not made it far into the reassembly process.
Re: Thriller MJ
« Reply #691 on: August 04, 2015, 04:30:49 AM »
is it the long side?
Re: Thriller MJ
« Reply #692 on: August 04, 2015, 05:22:14 PM »
I had to grind both sides.  Not a lot, it only took about a minute once I had the shaft out.
Offline Steve-O
Re: Thriller MJ
« Reply #693 on: August 04, 2015, 05:57:04 PM »
I'm glad you decided to grind it, don't forget to check the spindle bearing while it's off
new england toyotaz?
Re: Thriller MJ
« Reply #694 on: August 04, 2015, 07:09:28 PM »
Me too.  Thank you for your input!
Good call.  I don't have the hubs on yet, so tomorrow I will pop the spindles off and throw some grease on those bearings.
Re: Thriller MJ
« Reply #695 on: September 01, 2015, 08:36:00 PM »
A few wheeling pics from last weekend.
And I started to add lights.
Re: Thriller MJ
« Reply #696 on: September 01, 2015, 09:23:26 PM »
Looks like I missed a fun time !
The lights look good !
Re: Thriller MJ
« Reply #697 on: September 05, 2015, 07:04:46 PM »
Re: Thriller MJ
« Reply #698 on: September 05, 2015, 07:12:21 PM »
now its all ready for an inspection sticker!
Re: Thriller MJ
« Reply #699 on: September 06, 2015, 06:45:15 AM »
Where did you go froading
Re: Thriller MJ
« Reply #700 on: September 06, 2015, 12:01:46 PM »
Field and forest had an open weekend last week, and I went with Ian.
Re: Thriller MJ
« Reply #701 on: September 06, 2015, 07:41:40 PM »
I've had a good weekend progress wise, so far.
The front lights are wired and ready to go.  The rear light is wired on a separate switch so I can control it independently of the fronts.  The tail/brake lights are wired, but I only have 1 mounting bracket so I will need to get another to mount the other light.  The Firestik antenna has been mounted to a spring and connected to a working CB via a 3' coax cable (still need to tune SWR).  I also made a cradle on top of the fuel cell to hold the recovery bag that I won at the 'Q (Thanks Jeff @ Crown!).
« Last Edit: September 06, 2015, 07:42:57 PM by Twisty »
