December 05, 2012, 01:15:38 PM
08 JK QUESTION
Topic: 08 JK QUESTION (Read 156 times)
mud rover
08 JK QUESTION
October 09, 2012, 08:50:09 AM »
on my buddys 08 jk the ABS,REAR DIFF (and 1 other)dash light flickers on and off when hitting bumps or when he hits the brake he can feel the abs kick in.question is would you think this is the sensor for abs.but if it is how come the other light come on
01 jeep Tj
Re: 08 JK QUESTION
October 09, 2012, 09:38:35 AM »
is it under warranty still?
Re: 08 JK QUESTION
October 09, 2012, 10:15:13 AM »
What is the other dash light that comes on?
Does the abs kick in on light to moderate braking or jut hard braking?
If the abs light comes it should have a code I would recommend identifying the code first.
Crown Automotive - Jeff
Support your local vendors!!!
Re: 08 JK QUESTION
October 09, 2012, 12:25:58 PM »
when that happened with mine, it was the clockspring...covered under warranty at the time.
Open Mon-Sat 781-821-2276
SPYDER
Re: 08 JK QUESTION
October 09, 2012, 01:39:50 PM »
is his jeep lifted?
i would first pull the code. ive seen clocksprings be the cause the most. if there is no codes and/or its not the clockspring i would suggest looking at the rear abs sensor wiring. they are held in place on the axle at the control arm brackets, and ive noticed even with a 2" bb, when the axle is droped out they become extremely tight on the clamps that attach them to the bracket. as a preventative message on all the lifted jk's i dealt with at the stealership, i would remove the clips and use loosely attached zip-ties to hold them in aproximately the correct spot but allow them to move under flex/drop out.
08 GSX-R 600
mud rover
Re: 08 JK QUESTION
October 09, 2012, 04:50:38 PM »
Quote from: Mitch on October 09, 2012, 09:38:35 AM
if it was i wouldnt be posting this
01 jeep Tj
mud rover
Re: 08 JK QUESTION
October 09, 2012, 05:02:35 PM »
thanks..im just waiting for the code..then i will check it on alldata
01 jeep Tj
08 JK QUESTION
