September 21, 2015, 10:30:52 PM
Author Topic: Help ID this trans/transfer case please!!  (Read 235 times)
Offline rockdaletj
« on: May 13, 2015, 08:40:57 PM »
3 SPD trans mated to a Buick? 231 motor. Transfer case has a passenger side rear output to an offset d44. Twin stick.
Anyone have any ideas??
OK how do I post pics from my phone...saying file is too large...help!!
49 CJ3A
78 CJ7
06 TJ
Re: Help ID this trans/transfer case please!!
« Reply #1 on: May 13, 2015, 09:59:18 PM »
Try cropping the pic on your phone before you post it..it works for me.
« Reply #2 on: May 14, 2015, 03:37:52 AM »
Sight unseen
Adapted bell housing T90 Dana 18
T14 dana18
« Last Edit: May 14, 2015, 03:39:49 AM by rich »
Offline rockdaletj
« Reply #3 on: May 14, 2015, 05:11:23 AM »
OK I'm stumped on these photos. If I try to crop them on my phone I lose parts of the image. I am seeing no way to resize.
49 CJ3A
78 CJ7
06 TJ
Offline rockdaletj
« Reply #4 on: May 14, 2015, 05:20:27 AM »
Try this....
49 CJ3A
78 CJ7
06 TJ
« Reply #5 on: May 14, 2015, 06:06:54 AM »
Trans looks like a T90, but I am not an expert on vintage tranny's.
for the T-case, Based on what rich posted, Dana18 but I do not know.
Offline rockdaletj
« Reply #6 on: May 14, 2015, 07:23:21 AM »
It could be a Dana 18 case, the lack of e brake on the output is throwing me off, I'm used to looking at the one on my 49.
As for the trans, it could be a t90, so it would be stock trans/ case for a 2a with a 231 adapted to it. The trans does look a bit different than the stock t90 in my other flatty though.
49 CJ3A
78 CJ7
06 TJ
« Reply #7 on: May 15, 2015, 06:08:15 AM »
I believe that's a t14 transmission, used behind the buick v6.  It's a decent transmission not great but ok for light duty use.  It could be a t86 but I doubt that as they were not that common behind the v6 and they didn't hold up well to the power of the v6 and were swapped out very often. The t14 designation on 86 will be cast in the side of the trans if you look closely on passenger side.
And that is d18 tcase without the e-brake.
