September 21, 2015, 10:30:11 PM
The Slut
Topic: The Slut (Read 932 times)
Re: The Slut
Reply #30 on:
August 14, 2015, 09:10:25 PM »
not enough cooling (i dont have a shroud though)
SPYDER
Re: The Slut
Reply #31 on:
August 15, 2015, 07:02:21 AM »
Well that's your problem. Without the shroud your fan is 1/2 as effective as it's supposed to be.
Re: The Slut
Reply #32 on:
August 15, 2015, 07:47:20 AM »
i agree (hence me noting it) but with the flex fan as soon as i get any RPM which would drag air the fan goes flat. so yes it might help with my airflow at idle, but the 1500-2000rpm range i use on the trails it isnt pulling air either way.
Re: The Slut
Reply #33 on:
August 15, 2015, 08:27:19 AM »
clutch fan
Re: The Slut
Reply #34 on:
August 15, 2015, 08:30:14 PM »
Blacky, I have a Taurus fan if your iinerested, I can get measurements and pics.
Blacky
Shake and Bake
Re: The Slut
Reply #35 on:
August 16, 2015, 07:26:47 PM »
Quote from: jps4jeep on August 15, 2015, 08:30:14 PM
Thanks for the offer, I do have an electric fan already that I had on my white zj before I replaced it with a clutch fan, the fan wasn't the problem though. Maybe I'll try it out on the slut. It's a flex-a-lite syclone that is rated at 2500 cfm
'08 Ram 2500 tow rig
Re: The Slut
Reply #36 on:
August 16, 2015, 08:16:45 PM »
IMHO, many cooling issues I have observed and read about involve electric fans. I do not feel that they can replace a mechanical fan.
The Slut
