September 17, 2017, 07:24:10 PM
Author Topic: Winter plans?  (Read 940 times)
Offline Bosox
Winter plans?
« on: January 02, 2017, 03:24:23 PM »
What's everybody doing for upgrades this winter? Axle upgrades, motor swaps, bigger tires or???
Let's hear it...
SI VIS PACEM PARA BELLUM
Re: Winter plans?
« Reply #1 on: January 02, 2017, 04:30:17 PM »
I was going to work on getting the front linked this winter, but I have things to do at the house that take priority. (read as lack of $$$$$)
Re: Winter plans?
« Reply #2 on: January 02, 2017, 04:39:28 PM »
i still am halfway done with my fuel pump swap. its been that kind of winter.
Re: Winter plans?
« Reply #3 on: January 02, 2017, 05:13:47 PM »
Cleaning up wiring and replacing starter 😉  maybe if I'm motivated maybe add some nitrogen to my shocks to adjust ride hight.
On the 05 I just want to drive it as much as possible which I'm failing miserably at
Offline Blacky
  • Secretary
  • Shake and Bake
Re: Winter plans?
« Reply #4 on: January 02, 2017, 07:17:23 PM »
I bought a new pair of hiking boots ;D
Offline Bosox
Re: Winter plans?
« Reply #5 on: January 02, 2017, 07:31:44 PM »
Works damn good the way it is...
Did your steering pump ever finish shitting the bed?
Re: Winter plans?
« Reply #6 on: January 02, 2017, 07:52:07 PM »
Nope. And it never acted up again after that weekend. I think it was over heating
Re: Winter plans?
« Reply #7 on: January 02, 2017, 08:04:07 PM »
I am planing on changing the oil on my cj
Leaf sprung people matter
Re: Winter plans?
« Reply #8 on: January 02, 2017, 08:28:53 PM »
drive it to my barn and hang out
Re: Winter plans?
« Reply #9 on: January 02, 2017, 08:29:18 PM »
lol thats funny
Re: Winter plans?
« Reply #10 on: January 03, 2017, 02:37:13 PM »
OK
Re: Winter plans?
« Reply #11 on: January 03, 2017, 02:43:48 PM »
Spent a couple days over the past week of vacation and got to better organizing the garage.  Still have acouple house projects to wrap up, but the jeep is going to be a priority this winter.
  • Event Coordinator
Re: Winter plans?
« Reply #12 on: January 03, 2017, 11:44:15 PM »
I'm probably going to rebuild my rear axle :).   Or swap in new ones, whichever is easier.
Offline trav
  • wakka wakka
Re: Winter plans?
« Reply #13 on: January 03, 2017, 11:45:03 PM »
I need to figure out the clicking sound that happens during higher torque takeoffs from stop. It seems like its coming from the t case. I know its not my rear drive shaft clearances but maybe the rear drive shaft is to short ? almost like its pulling out of the SYE housing? is that even possible ?
The temp fix is I have 440 lbs of sand tubes in the back of the jeep (02' TJ w/ 4" Nth long arm lift converted to 6" with springs and what not... )
The sand squats the ass end down and eliminates the issue. Im thinking of cutting the front and rear springs to lower it down 1". I measured the height difference  of sand and no sand and it is exactly 1".  Sooooo yeah. I think Im going to borrow some cameras, mount them underneath and make some videos and hopefully see exactly wtf is happening before I chop springs though.
« Last Edit: January 03, 2017, 11:49:17 PM by trav »
:booze:
Re: Winter plans?
« Reply #14 on: January 04, 2017, 04:18:27 AM »
I probably should figure out why my links keep spinning and fix that.
