December 05, 2012, 01:18:04 PM
Proud owner of a new to me Rubicon
Topic: Proud owner of a new to me Rubicon (Read 377 times)
Supremeteam
October 29, 2012, 12:40:54 AM »
I bought a Rubicon from a coworker and got it at a great deal, this is because it needs some TLC. One of the major issues I see is that the reared might be on the way out. I have it onjackstands waiting for some new shocks and I took the tires off to check the brakes and while it was off the ground I decided to run it with no load and no knobbies making noise. I felt a slight vibration and heard a little humm. My friend said sound like the gearing is worn and could be going. We noises fluid coing out of the axles and so we are gong to do the bearings and seals on the axles, along with the emergency and regular brakes. If I put it back together and still feel it the Im going to need to get that done, anyone know a good jeep shop around Boston that can do Dana 44 rear ends?
Newbie
Re: Proud owner of a new to me Rubicon
October 29, 2012, 07:12:49 AM »
Check out our sponsoring shops/vendors. Elias is not far from boston, Chris can fix anything but a broken heart.
October 29, 2012, 07:19:15 AM »
Quote from: jps4jeep on October 29, 2012, 07:12:49 AM
x2 they can do all your maintanice/repairs
October 29, 2012, 08:29:32 AM »
it sounds more likely like bearings, rather than the gears, but you never know.
October 29, 2012, 09:14:11 AM »
Congratulations on your new purchase
When you had it on stands and under power were the tires spinning true?
How many miles?
SPYDER
October 29, 2012, 10:34:50 AM »
one other thing to consider is driveline...im going to assume you have the jackstands under the axle, but if its supported by the frame the driveshaft might be slightly binding...id check u-joints before throwing money at the diff.
08 GSX-R 600
Elias 4wd Center
978-597-8432
October 30, 2012, 12:55:46 PM »
It probably just needs maintenance, we do a lot of bearings and seals on those.
We also offer a one hour inspection service to go from front to rear and top to bottom.
That's one hour on the lift with Chris.
Usually there is another 30 minutes gifted to write it up and go over everything with you.
If there's work it does need or will need, Chris will find it.
Nice Jeep!
Elias 4WD Center 978-597-8432
"Commitment to Quality"
http://stores.ebay.com/elias4wdcenter
- Check here for deals and specials
Supremeteam
October 30, 2012, 09:29:08 PM »
I had the Jeep on the stands by the frame and so that when the shocks come I can just swap them out. I didn't want any load on the axle and shocks. When I tried running the jeep in the air the tires were already off. I don't know if it was bad axle bearings or a drive shaft that is out of balance but I will know that before I send it to the shop for rear end service. I just cut off the old bearings and stuff and pressed all the new things on today so if there is no rain tomorrow I can thought that stuff on. And it has 206k on it. My friend bought it new and was doing like 90 miles a day just back and forth to work.
Last Edit: October 30, 2012, 09:31:37 PM by Supremeteam
Newbie
Supremeteam
October 30, 2012, 09:33:15 PM »
Quote from: Elias 4wd Center on October 30, 2012, 12:55:46 PM
Nice Jeep!
Okay thanks if I see that the problem points to the rear end Im bring it straight to you guys!
Newbie
October 31, 2012, 07:51:27 AM »
Quote from: Supremeteam on October 30, 2012, 09:29:08 PM
Quote from: Axle on October 29, 2012, 08:29:32 AM
October 31, 2012, 08:05:29 PM »
did I win?
Supremeteam
November 01, 2012, 10:17:36 PM »
Quote from: Axle on October 31, 2012, 08:05:29 PM
did I win?
Win the chance to fix my Jeep? Sure you did! I'll let you do and I won't even charge you
Because of Hurricane Sandy I haven't gotten a chance to put the axles back in yet. Also the bags I had covering the axles blew off during the storm and I'm not sure if water had got in there, so I got a new gasket and I'm gonna take off the diff cover and drain out every thing and do a little inspection and see how the bearings look if possible.
Newbie
November 02, 2012, 08:31:33 AM »
when I say bearings, I mean axle shaft bearings, not carrier bearings.
Reply #13 on:
November 02, 2012, 08:50:28 AM »
Quote from: Supremeteam on November 01, 2012, 10:17:36 PM
You'll have to remove both shafts and gears to inspect the carrier bearings.
