February 07, 2012, 10:05:36 AM *
Author Topic: tj lift  (Read 1077 times)
« on: February 01, 2009, 04:45:57 PM »
My bro in-law just bought a tj and wants to put a 4" lift in it and run 33"s. What is a good kit and how much?
97ProjecTJ
« Reply #1 on: February 01, 2009, 05:00:17 PM »
Out of all the kits Ive seen and read about, the RE 3.5 is the best 4 inch lift. The re's usl settle a little higher. Def enough for 33's.
http://www.cardomain.com/ride/3022344
« Reply #2 on: February 01, 2009, 05:13:38 PM »
re 3.5 basic kit, forget the control arms..you can do that down the road.
why didnt he buy my tj!! lol
« Reply #3 on: February 01, 2009, 05:33:43 PM »
How much?   and thanks guys! how will it drive with the stock arms?
« Last Edit: February 01, 2009, 06:11:19 PM by Axle » Logged
Captian Carnage
Rock+ Roll
« Reply #4 on: February 01, 2009, 10:26:27 PM »
I ran 33s with 2 in spacer + 1 in body  Snapped 1 tail shaft + bent the 2nd 1
After install I got 4 1/2inches out of it  With my winch + ft bumper  It dropped a inch Then My tool box in back with spare parts and tools droped the back 1 inch
Mine drove ok with it  you will I did   a SYE  + New rear shaft   I am running 35s with the 3 1/2 RE + 1 in BL I have the 8 ADJ control arms + rear Trac bar
  Your looking at around $575 - 600
 RE Recomends a SYE + REAR SHAFT
« Last Edit: February 01, 2009, 10:32:09 PM by Captian Carnage » Logged
I know how to Rock + Roll
Dont matter if its wrong or right Do it a 100%
« Reply #5 on: February 01, 2009, 10:45:39 PM »
You can either get a decent kit, and run that, or just put some new springs and tracbars in.
Whats his budget?
« Reply #6 on: February 01, 2009, 10:46:28 PM »
I wonder if you could cut down a stock XJ front shaft.  I bet you could.  That would save a few dollars.
RMFJ78
« Reply #7 on: February 01, 2009, 11:02:46 PM »
I run a shortened xj front shaft in the rear of my tj (thanks adam)  in the end it cost me i think over $200 to have it shortened, balanced and rebuilt (new double cardan joint and 3 u joints, the DC costs $70 alone)  I actually ordered a Tom Woods last week so if he wants to do a SYE i can sell him a rebuilt (less than 500 mi on the dc joint and u joints) shortend xj shaft.
Bob, I ran a BB and BL with 33s for a while on stock arms, it worked very well for me.  Now I have 4.5" springs and a BL and clear 36s with room to spare.  I wouldnt go more than 3-4" with short arms, mine rides very harsh with the steep control arm angles.  Over the 2" spacer height youll need an adj front trackbar and rear trackbar bracket, shocks/brake lines.  As cpt carnage did, I bent the output shaft on the tcase at only 2" of suspension lift when I upgraded to the sye.  If its in the budget get it right away, if not you can get away with a tcase drop to get rid of vibes for a short time.
Bald is beautiful
« Reply #8 on: February 01, 2009, 11:10:21 PM »
Just say no to the  Tcase drop kit.  Cheap fix but takes away the reason for the lift (to gain clearence)  If its a DD and a look but don't wheel then thats understandable but with a bro in law like Bob he will probably wheel with us no?
83 CJ7
« Reply #9 on: February 02, 2009, 12:13:42 AM »
start out with the 2" BB and 1" BL. If he sticks with wheeling, he will upgrade, if not it will look cooler than 98% of the jeeps on the road, make that 99%...mine is still broken.
lol
Captian Carnage
Rock+ Roll
« Reply #10 on: February 02, 2009, 07:34:08 AM »
 My front shaft was good for a year of hard wheeling  It was not greaseable thats why it went
Allmy driveshafts I get fromCustom Driveshaft in Spofford NH Right on rt 9 they are $ 270 a piece and made to fit your  jeep It was $75 to shorten my rear DS
« Last Edit: February 02, 2009, 07:41:28 AM by Captian Carnage » Logged
« Reply #11 on: February 02, 2009, 08:22:11 AM »
stock control arms will run well enough until the bushing get shot.
Captian Carnage
Rock+ Roll
« Reply #12 on: February 02, 2009, 08:59:21 AM »
mine always got bent  for some reason LOL
« Reply #13 on: February 02, 2009, 09:28:16 AM »
Thanks guys.
« Reply #14 on: February 02, 2009, 09:35:52 AM »
If the desired tire is 33, on a tj, I would use a bds 2 inch spring lift and run a 1 inch body lift. Will be more than enough for 33's, won't break the bank and will leave some cash for a SYE or a locker
