February 02, 2011, 04:08:44 PM *
Pages: 1 [2] 3 4   Go Down
Author Topic: 1996 Jeep XJ (insert cool build name here)  (Read 813 times)
X-BoB-J
J33P
« Reply #15 on: August 12, 2010, 07:36:52 AM »
nice jeep mitch i seen it a lot in worcester!
my OBD connector was messed up also, would not read. eventually i figured it out and it was a bad ground on the connector.
im in the process of redoing my rockers just how todd did.
heres what they looked like. i just got to get some steel.
« Reply #16 on: August 12, 2010, 07:41:16 AM »
the little connector by my knees? Your rockers have seen better days - your not selling that anymore - KEEP IT! Cheesy
X-BoB-J
J33P
« Reply #17 on: August 12, 2010, 07:45:34 AM »
i did a ton of work to it. im keeping it now.  yes the connector by your knees ill try to dig up the pin diagrams again.
« Reply #18 on: August 12, 2010, 08:14:48 AM »
regarding the o2 sensor, to get the vehicle to pass, you can get a phantom o2 sensor.. I am not positive that is the name, I will have to search, but the import tuner guys use these to fool the ECM into thinking that the o2 senor is connected and working properly. you unplug the sensor and plug this one in, basically, it sends the computer the proper voltage readings that a working and functional o2 would send. not sure if I completely understand why yours would not connect or even if this would be the best solution, but thought I would mentioned it.
Good Luck.
A diamond might last forever, But she will never forget the crabs you gave her!
X-BoB-J
J33P
« Reply #19 on: August 12, 2010, 08:15:11 AM »
OBDII connector
#4 - Chassis Gnd
#5 - Signal Gnd
#7 - K
#15 - L
#16 - +12V
on my jeep pin number 4 was not grounded. so i cut it and grounded it in the cab. that fixed my problem.
« Last Edit: August 12, 2010, 08:22:58 AM by X-BoB-J » Logged
« Reply #20 on: August 12, 2010, 08:16:00 AM »
Oxygen sensor simulator is the name I think..
« Reply #21 on: August 12, 2010, 08:25:55 AM »
Thanks guys, it may connect now - it hasnt been tried since he last replaced parts. But this is some excellent tech for me should I need it.
What year is your XJ Bob?
X-BoB-J
J33P
« Reply #22 on: August 12, 2010, 08:27:18 AM »
99 but same connector, 96 then went to OBDII, just plug in a OBDII reader and if it reads it should pass inspection.
« Reply #23 on: August 12, 2010, 08:28:17 AM »
does autozone do that? I dont have a reader.
X-BoB-J
J33P
« Reply #24 on: August 12, 2010, 08:30:04 AM »
big d has one also if your going to see him anytime soon.
yeah just ask them if they can read it.
heres the link of the connector.
http://www.obdii.com/connector.html#dates
« Last Edit: August 12, 2010, 08:31:43 AM by X-BoB-J » Logged
Bald is beautiful
« Reply #25 on: August 12, 2010, 08:42:32 AM »
BigD had one.  The last time it worked was when I let you borrow it  Grin
Not blaming you as my little one could have got at it but hasn't worked since.
I get an Err on my screen and nothing more Sad
Gotta get a new one
83 CJ7
« Reply #26 on: August 12, 2010, 01:46:54 PM »
Forgot to order e-brake cables.
This is a test, as there isnt really anything for a 96 XJ with a Ford 8.8 w/ Disc brakes available that I could find.
So I ordered 2x Part #: DB05 from Jeff at Crown. Thanks Jeff!
« Reply #27 on: August 12, 2010, 02:08:30 PM »
how about "project get Mitch on the trail"
« Reply #28 on: August 12, 2010, 06:58:15 PM »
Got to get it inspectable if I'm going to make the trails or get to work! I'm wheeling this weekend Bobbo!
UPDATE! (already!!)
Installed hood release cable
Replaced cracked rear pass tail light
Drum roll......  Installed cup holders!!! It sucks not having these! Yay!
Crown shipping rocks! Got the less than 24 hours after I ordered!
Bald is beautiful
« Reply #29 on: August 12, 2010, 09:47:52 PM »
I have ordered through Crown (Jeff) and always been happy with getting my package next morning....even when I get off the phone with him at 4pm Wink
83 CJ7
Shop at New England Jeepz Online Store!
Pages: 1 [2] 3 4   Go Up
