October 02, 2015, 11:04:52 PM
Author Topic: Start here! Newbie introduction thread  (Read 39057 times)
Offline GlacierFungus
Re: Start here! Newbie introduction thread
« Reply #720 on: May 06, 2015, 05:39:01 AM »
welcome to the board.  are you dropping it down from 6" or putting in a 6" lift...cause if you are putting it in, what size tires are you planning on running cause even on 37's that's too much lift.
35s, And I'm lifting it 6". I should have been more clear, my bad. and the 6" lift was kinda on a whim, I found it for $700 brand new on craigslist. I ordered a 4.5 but I couldn't beat the price. 35s will be fine for now. When I 1 ton my axles, ill upgrade my tires. I'm already regearing.
97 TJ 6" RC Lift (in the process)
Just because I'm new to a forum, doesn't mean I was born yesterday.
« Reply #721 on: May 06, 2015, 09:38:50 AM »
Ok. Sounds. Good.  You are gonna end up a little tall but should have no issues around here where we wheel.  I'm just under 6" but have everything but time and motivation to lower mine down.
« Reply #722 on: May 06, 2015, 10:08:36 AM »
Hi Nick, welcome to the forum.
You don't happen to know where I can get a good deal on some can bolts do you ?
 ;D
« Reply #723 on: May 06, 2015, 11:09:47 AM »
you might have a hard time finding them up your butt so crown has them in stock  ;)
« Reply #724 on: May 06, 2015, 03:37:03 PM »
Welcome. The type of wheeling we do less is more when it comes to "lift".
« Reply #725 on: May 07, 2015, 06:52:45 AM »
Caves? Ha
« Reply #726 on: May 07, 2015, 07:50:42 AM »
Tippy spots where low center of gravity is helpful.
« Reply #727 on: May 07, 2015, 04:20:03 PM »
For mud and snow you can add all kinds of lift.  We stick to rocks and trails that are tippy.
« Reply #728 on: May 07, 2015, 05:11:44 PM »
Welcome. Ditto on mentioned, for 35's on a tj, most here run 3-4.5 inches of lift. Adding wheel base will net better results than adding height and ultimately fit a larger tire.
