September 12, 2015, 02:08:56 AM
Author Topic: cracked axle tube  (Read 230 times)
cracked axle tube
« on: July 21, 2015, 08:24:55 AM »
going to fast and getting air is a bad thing. Should I weld this with my little Hobart 140 (110) or have someone with a big unit do it?
Re: cracked axle tube
« Reply #1 on: July 21, 2015, 08:39:34 AM »
Big machine, is the tube actually cracked or just the weld?
« Reply #2 on: July 21, 2015, 09:15:43 AM »
You could short term seal the leak with the 110 so as to not miss any wheeling
« Reply #3 on: July 21, 2015, 09:47:39 AM »
I would use the machine you have Bob, just make sure you prep the crack. Drill stop holes at each end, and grind a deep V into the crack.
« Reply #4 on: July 21, 2015, 11:04:05 AM »
I have a big unit
« Reply #5 on: July 21, 2015, 11:24:18 AM »
I was waiting for that lol
« Reply #6 on: July 21, 2015, 11:43:43 AM »
Too add to what Chuck said, I would spray the piss out of it with brake cleaner.
« Reply #7 on: July 21, 2015, 12:00:51 PM »
Thanks guys, one of the OSJ guys is near me, Ricky with the yellow 1 ton tj , he can do it for me I think. I really want a deep penetration from a big init. ;)
« Last Edit: July 21, 2015, 12:01:53 PM by Axle »
« Reply #8 on: July 21, 2015, 12:41:00 PM »
 ;D
Offline Steve-O
« Reply #9 on: July 21, 2015, 01:03:47 PM »
Just be careful doing that because it lets off some nasty fumes
new england toyotaz?
« Reply #10 on: July 21, 2015, 02:42:35 PM »
non chlorinated brake cleaner is cool.  chlorinated cleaner is deadly when you when after.
« Reply #11 on: July 25, 2015, 07:31:10 PM »
all welded back together ;)
« Reply #12 on: July 25, 2015, 08:16:31 PM »
 :cheers:
